246 tcase questions
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Makes since... I cannot find that same info anywhere else. Would be really nice if it did take the same fluid... I think maybe they looked up the non auto 4wd case.
Curious as though what is it that precludes the np246 from using dexron 6? I am rebuilding one and if possible would like to make it use dexron 6 so I don't need to keep a special fluid on hand.
Fless
Super Moderator
Elev 5,280
rockola1971
Indiana (formerly IL)
The unit using standard Dexron fluid do not have clutches in them for the Auto 4wd since they do not have Auto 4wd function. Not a common animal out there but they are out there. Both of my 2003 LT's have the Auto 4wd. The non Auto 4wd probably are in the base model Tahoe, Yukon, K1500, Sierra, etc.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I kind of wondered. They must need the special fluid so the clutches slip a bit and allow for less friction / heat. I read those articles and it is a PWM function that applies and releases clutches quickly. I think in automatic transmission there is very little slip in clutches like that. They either lock up or release. Is my theory... must be a slip additive in the autotrack fluid?
rockola1971
I believe its a friction modifier.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I need to spec out rebuild parts and or just buy a kit. Any suggestions?
- Case saver
- Case vent elbow
- Not sure if clutches wear out? They are cheap though
- The clutch fork plastic lip deal (I want one that goes over whole end of fork)
- Shaft seals
- Shaft bearings? There is ZERO perceivable play in the input and output shafts.
- Chain? I assume some slack is normal not sure what spec is though to check if I need a new one
- Planetary gear set - Considering buying the 6 pinion. Isn't too expensive.
- Rebuild / gears for encoder motor?
rockola1971
- Case saver
- Case vent elbow
- Shaft seals
Im guessing the Tcase is all original and was in a 2001? Replace all bearings, seals, Auto clutches, chain, fork lip and any hard parts that fail inspection. Makes no sense to replace a little of this and that for something like a bearing or chain to fail and destroy your Tcase. Do it once and be done for a long time. I always replace the Auto clutches on a Tcase that is well used. Be sure to soak all the clutches in autotrac fluid overnight before assembly!
Harbor Freight has cheap bearing and seal drivers. You will also need a set of internal/external snapring pliers with extended reach(nose). Thats about it for "special tools".
You run into any questions feel free to ask us anytime. There are tons of youtube videos on the 246 case disassembly/reassembly and most of them are pretty good. Dont let the Tcase intimidate you. There really is not alot to them. They sure arent anything to the level of a transmission and not near as many parts.
Just take your time and dont be in a hurry.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Just finished 4L60E build :) Transfer case and steering gear box are last things not rebuild on my truck. I wouldn't mind to upgrade it a bit on way too... I'm thinking of that 6 pinion planetary. Truck is used quite a bit off road on moderate trails, no rock crawling stuff though.
I'll just do a complete rebuild. You know of a kit or brands I should steer clear of?
I noticed non GM / OEM chains are MUCH cheaper.
antennabob
