4l60e transmission question
On3honksgo
My transmission went out in my 98 tahoe today, what other years 4l60e are compatible. Im hearing 98+ are different??? Is this true, i have called multiple trans shops and researched, i cant get a straight anwser.
Just need to know what years i have that are compatible
ccapehartusarmyINF.(ret)
Gilbert AZ
the turbo700r4 was renamed the 4l60 in 1990 and in 97 they came out with the electronic controlled 4l60e
The 4L60E featured a three-piece aluminum alloy case that consisted of the main case, tailhousing and bellhousing. It was 21.9 inches long with a 30-spline input shaft. It had a square oil pan. Pre-1997 4L60E transmissions had a four-bolt square pattern on the case cover, while the post-1997 version had a six-bolt hex cover pattern
they did not do anything to the transmission in 98
Gilbert AZ
97 till 2006 is when they stopped putting it in vehilces
just get one out of a similar vehicle tahoe suburban or pickup
i think they differ from model to model like a 4l60e from a corvette is very different then a tahoe one
SunlitComet
OBS Jedi-Do Good
unknown at this time.
they change the bell housing/case setup in "98 and it uses a bigger converter. anything 98-2000 will drop right in1997 or older may require some extra donor parts.
Dneel81
OKC
just yanked one out of my 1997 if you are close by you can have it. I'm in Oklahoma City, OK.
Shifted nice and had no troubles that I'm aware of.
Roux
