4x4 is messed up?
Symba_The_Lyon
Hey there my 4x4 is messing up and I am dumfounded what's happening is when I put in neutral to put in 4x4 the 4 hi and low just sits there and blinking till I put it into 2wd but I changed the frount acutator and now it does the same thing with the blink lights when trying to put it in 4x4 but 4l works now but still blinks on the dash but when I put it in 4hi it does nothing and also you can hear the famious clunk when you try and shift it in to 4x4 any ideas? I'm hopeing someone on hrre could lend me a hand thank you!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If the t-case shifts and the actuator moves I would suspect a broken shift mechanism in the front or the feed back switch circuit is not working properly.
rabbiporkchop
Pennsylvania
Time to upgrade to manual shift. Cheaper and easier to fix. It only cost me 200 bucks to convert a 99 from auto to manual.
Symba_The_Lyon
Symba_The_Lyon
Wher is the shift mechanism? Is it on the t case? All of this happened after the trans shop rebuilt my tranny 600 miles ago
Symba_The_Lyon
Symba_The_Lyon
I was reading that the encoder motor could be bad that's why the lights just sit there and blink do you think that's true? And also is there a way to reset the 4x4?
Enrique01
