5.3 Tick/Knock?
JPVortex
JPVortex
Connecticut
Sounds good. Interested to see what you find. Take pics of where you tap into for the mechanical gauge, etc..... and not sure if your plan is to have a gauge permanently, if so, I'd definitely use this instead of the cheap plastic tubing that comes with the mechanical gauge
Will do! And right now I’m just doing a temporary test. I think I’m going to be tapping into where the sending unit usually goes.
JPVortex
JPVortex
Connecticut
Yeah so about that oil pressure test, that’s not happening. Lost the adapter, it fell onto the bell housing then to god knows where. Should’ve tested it somewhere else. Just going to throw a sending unit on it and see what it reads on the cluster.
YukonKris
