5.3 vs 6.2 octane
intheburbs
SE MI
6.2L can & does run on 87. The motor dials things back to accommodate the loss of energy being supplied vs demand.
“IF” you’re running 87 towing, under load (hills), taxing the motor w/ in high temps or speed, your normal margin of safety gone.
My folks can’t fathom paying for premium fuel. It’s something that truly upsets them. They feel premium fuel is a rip off. Because of that, they only purchase vehicles made to run on 87 here in Cali.
I have another buddy that feels the same way but also felt that his wife’s Lexus RX300 was ok to run on 87 driving up to 6k mountain roads w/ heavy loads. When the alternator bearing went out the dealer offered them $10k+ toward a RX350 on trade. They laughed and said jay fix the alternator. The dealer let them know they prolly had a cracked piston. They did.
If you don’t want to pay for premium fuel, no biggie. Just don’t purchase a premium fuel (recommended) vehicle and run 87. The road you’ll go down may be expensive. It’s a roll of the dice.
There's no "loss of energy" between 87 and 91/93 octane. Both grades of fuel have the same amount of energy per gallon. The only difference in how easily the fuel burns/detonates. 87 burns/detonates faster and at lower pressures. The 5.3 has a compression ratio of about 9.5:1. 87 octane runs fine in these engines. The L9H 6.2 in my Denali has a 10.5:1 compression ratio. Anything over 10:1 is generally considered to be high compression. This means the air/fuel mixture is subjected to higher pressures, and the ideal gas law states that as the volume goes down (it's compressed more), the pressure and temperature go up. A low-octane gas might get so hot under that higher compression that it ignites before the spark plug fires, and then the "wave front" of the explosion crashes into the piston as it approaches the top of its stroke. That's the knock/ping you hear, and as you described in the Lexus, that's what leads to cracked pistons.
There's no "safety margin" when you're talking about octane. If you're running low-octane gas in a high-compression engine, you're "hoping" the knock sensors and the computer can adjust the fuel mixture to eliminate/reduce the knock. But it's not instant, and the owner's manual says you may hear a "slight" knock. To me, that's unacceptable. I'm not going to trust those systems to prevent damage to the engine. Instead, I'll feed it the gas it was designed for. Running lower-than-recommended octane gas in a high-compression engine will cause damage. Period.
And up in the mountains, at 6,000 feet, the reduced oxygen levels in the air actually cause gas to behave like it has higher octane. That's why regular gas in Denver is 85 octane, and premium is 91. The thinner air effectively increases the octane of the gas by about two points, so 85 in Denver behaves like 87 at sea level.
jeffbco
This is straight out of the owner's manual for my 6.2 Sierra Denali (2009):
Yes, it says you can use 87. I don't. Why? Because the 6.2 is a "high-compression" engine that inherently needs higher-octane gas. And frankly, I don't trust the knock sensors and the computer to be able to adjust the timing well enough to fully control knock/ping. The manual even says that, you might hear a "slight" knock. :mad: Using 91+ octane gas is, IMHO, cheap insurance against possible engine/piston damage.
That, plus the fact that when I floor the throttle, I want all 400 ponies present and accounted for. :)
I'm actually tempted to take it to the other extreme and run E85 in it. If I'm willing to tolerate the abysmal mileage and limited range (10 MPG with a 26-gallon tank), E85 has an effective octane rating over 100.
I didn't realize the 6.2 was a flex-fuel engine.
BG1988
91 is best. It is due to the compression ration, cam timing, spark timing etc.
It will run fine on 87, but the knock sensor will be triggered quite a bit..
This then tells the computer to make reductions in timing and cam timing VVT.
So you will lose fuel MPG and HP for sure.
Def always run good premium if you are towing or have heavy loads
87 oct is fine if you in a pinch
enough to get you to the next station
this 6.0 is running 10.8 compression
compression can increase " if the cylinder is dirty"
H
h2100
White Lake, MI
excellent info, thanks!
mikeyss
Longmont, Colorado.
I'm sorry, but if you're going to buy a premium vehicle that has an engine that requires premium fuel to keep it from pinging or whatever... Than don't be a cheap ass and use the wrong fuel for it because you can't afford it. Don't buy a vehicle that you can't afford to operate properly. I LOVE escalades, but I didn't buy one because I know I can't afford some of the higher end stuff that would eventually break, like the MRC suspension. It really gets me that people buy a 6.2 that is meant to be a upgrade compared to a garden variety 5.3, and then treat it like it's a 5.3 and claim it's ok. High compression engines require better fuel, no matter if you're towing or not. Why buy a premium engine/vehicle if you're gonna just trash it by using inferior shit to keep running it? If you want to use 87 octane in a 6.2, knowing it's gonna make WAY less power because it's adjusting for the shit fuel.... Then why not just buy a 5.3?
IROCQUE
Toronto, Ontario, Canada
My 2018 Tahoe with the 5.3 runs good with mid-grade 91 octane, however I did run 93-94 Octane when I tow my travel trailer and it seems to run much better. Now that I have the 6.2 in my 2020 RST, I plan to stick with 92 octane as best as possible especially when I pull the travel trailer.
H
h2100
White Lake, MI
thanks, but i'll stick to the data driven analysis
VicVal01
