5.3 vs 6.2 octane
wjburken
Eastern Iowa
I'm sorry, but if you're going to buy a premium vehicle that has an engine that requires premium fuel to keep it from pinging or whatever... Than don't be a cheap ass and use the wrong fuel for it because you can't afford it. Don't buy a vehicle that you can't afford to operate properly. I LOVE escalades, but I didn't buy one because I know I can't afford some of the higher end stuff that would eventually break, like the MRC suspension. It really gets me that people buy a 6.2 that is meant to be a upgrade compared to a garden variety 5.3, and then treat it like it's a 5.3 and claim it's ok. High compression engines require better fuel, no matter if you're towing or not. Why buy a premium engine/vehicle if you're gonna just trash it by using inferior shit to keep running it? If you want to use 87 octane in a 6.2, knowing it's gonna make WAY less power because it's adjusting for the shit fuel.... Then why not just buy a 5.3?
I agree 100%.
When I made the decision to buy a “premium” suv like my Denali’s, I accepted the fact that they may cost a little more to operate and maintain. That being said, to each their own.
St. Louis
Not all spark knock is audible, and usually already doing some kind of damage by the time it's heard.
Knock sensors are good to have, but they're just basically "listening" for knock then making the ecu retard the timing when it hears it, hopefully in time and not doing any major piston damage.
Best to use the fuel the manufacturer recommends.
Premium 93 octane is currently $1.88 around here. I always use either premium or E85 in my 6.2l
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
donjetman
I bought a 12 yr old Denali for less than $10k. I wish it had a 4.8L in it for better gas mileage. I have very little need for its 6.2L and hp. I bought it for the AWD, amenities, and its awesome quiet smooth ride. I run mid grade 89 octane in it and get 16.5 mpg. I did run 87 octane until I got a DIC knock sensor message once on one of our road trips. Maybe I'll run premium for the next yr and see what the data says.
St. Louis
donjetman
It has a lot to do with atmospheric pressure. At sea level the pressure is about 30 inches of mercury or 15 psi. At 10,000 ft, Leadville, CO, its 20 inches of mercury or 10 psi. Lost about 1/3 of the pressure that's being forced into a normally asperated engine, so we lose about 1/3 of our horse power. So my 380hp 6.2L only makes about 250hp at Leadville. Cylinder pressure is reduced as altitude increases, so detonation, pre-ignition, knock is reduced, so the need for higher octane is reduced.
avalonandl
Troy, MICH & Naples, FL
Seen lots of Denalis with broken pistons from running low octane gas in them. The 5.3 in the later generations make a lot more power than yours, test drive both engines. I run high octane fuel in everything, even my lawn mower and generator, more power more power!!!!
Swath: There is a Racetrac nearby selling E85 for 1.45 vs. 1.95 for premium at costco -( 2.25 at Racetrac)
Am I better off trying a tank of E85?
I would! We have E85 for $1.35, my wife apologized for letting the mileage drop and I said who cares, we can fill the whole truck up for less then forty bucks! That last tank delivered about 10.5 MPG and cost just thirteen cents a mile which is this truck's record low. E85 is good for the motor and injectors, cleans them up.
Didn't have enough fuel on board to run down south yesterday so we refilled a little early with E15 on top of the E85 and still averaged 16 MPG @ 75 MPH. That should bust the thirteen cent record nicely!
If you run a couple tanks of E85, it will get up to full strength and the computer will adapt to it, even the transmission.
Leardriver
cOLORADO
I like Intheburbs answer.
I ran a dyno in Denver at high altitude. Several absolutes were clear.
In a normally aspirated engine, meaning no turbo or supercharging...
Your octane requirements go down about one point for every 1,000 feet above sea level. If you need 91 at SL, 85 runs the same in Denver.
Run the lowest octane fuel that your engine doesn't detonate on if energy and wallet efficiency matters to you. High octane fuel isn't better fuel, it could be argued just the opposite. It has more additives to resist detonation, and it burns slower. Lower octane burns faster and creates more energy IF the engine can peacefully exist, which at high altitude is virtually always. The argument that 85 octane makes more power than 93 is true-ish, but that's an oversimplification. The tradeoff for high octane burning slower than low octane is a tiny bit less explosive power, but you would never feel it.
We had a dirt bike dyno, and would measure bikes with great smelling 104 octane race gas in the CRF450R, and they would make 2 hp less than 91 octane pump gas. I raced MX for 25 years, and always said that if you want to go faster, twist the throttle. Those bikes make more power than mortals can use.
If you are towing a heavy trailer up the mountains, more octane doesn't hurt for that tank as an extra dissipator of heat. The higher altitude of the mountains, and warmer summer air actually reduces your octane requirements even more, but when you are on the gas non stop on long hills, more octane gives you a cheap source of additional margin.
jrmhokie
