6.2 or Diesel?
B
BobbySC
6.2 if you don’t intend to tow anything. Love my ‘22 Denali XL
Oh will be towing. 6/7
I don't think you can go wrong with either the 6.2 or the diesel, based upon your stated use cases. The diesel will provide better gas mileage, but the 6.2 will be more fun to drive, if you like to drive spiritedly (versus just using the vehicle to go from point A to point B).
ha. My wife laughed. I’m not very “spirited” behind the wheel.
Stbentoak
and the baby Duramax is absolutely suffocated with emissions control nonsense that will fail , will cost a fortune to fix, and will reduce engine life among other things.
Absolutely zero DATA to support this... With EGR post DPF, and DPF close to Turbo to keep it hot and clean, probably one of the better designed light truck Diesels out there.
and I also have had 4 others besides this one. Worst was the Eco Diesel and was still covered under the emissions warranty when I had a problem. Many LM2's are +150K miles now and still humming right along. Are you expecting it to be a Kenworth?
Antonm
Look's like a lot of "zero DATA" below (especially considering this was literally 30 seconds worth of google-ing)
You know, this very forum has a section just for the diesels, lets take a look in there on the first page and see what we find.
Yeap, emissions crap issues.
But there's "zero DATA" after all, so I must be imagining stuff.
All modern diesels (even the Kenworth's you joked about) are less reliable now than they were just 10 years ago.
Easy example, I have three Cummins 12 valve powered vehicles , in one case I swapped the engine into a Ford truck when the engine had 330K miles on it, no issues, would drive that truck anywhere without concern of being left stranded because of the engine.
Okay, this is a GM forum, my now old 2003 gasser 2500 truck with a 6.0 LS (well technically an LQ4) that I bought new, it was at 300K miles when I sold it, no engine issues, (it had gone through one transmission though), and that truck got beat with heavy trailers at high speed through mountains.
So what's different such that these late 90's and early 2000's engines where so much more reliable,,, oh yeah, the emissions crap they're forced to have now,,, that (and I repeat), will fail , will cost a fortune to fix, and will reduce engine life among other things.
The LM2 (along with all other DPF/ EGR/ SCR diesels) are crimpled by their required emissions equipment.
aboss3
Why would you not tow w/ the 6.2? It has 460 ft-bs of Torque...The Duramax for 2025 and beyond has 495, they are in the same neighborhood.
I tow w/ my 6.2L all the time, it is a happy and stress free experience.
If you plan to tow frequently or do a lot of highway miles, the diesel’s efficiency (and hence total range on a single tank) is a real advantage. You’ll spend less time at the pump, and the engine generally runs at lower RPM when pulling a trailer, which can be more relaxed on long trips.
viven44
Dallas, TX
If you're set on a Tahoe/ Yukon, then the safest bet for engine appears to be the base 5.3.
This... GM has problems with the 6.2L... Wouldn't even go near it with all the failures reported in the forum and reddit until the NHTSA investigation has resolution.
WalleyeMikeIII
Sunny and Snowy Minnesota
I’ve heard (from posts on this forum) that a relatively large towing load on the 3.0 and it drinks DEF at a pretty high rate. It’s a great engine, no denying it. But it’s no tow monster like the larger diesels in the HD trucks. Perhaps one of the members that has it can chime in on towing fuel economy. That said, if one plans to eat up the miles on long road trips not towing…the 3.0 is the choice to make.
KEITHC69
