97 YUK Brake Nightmare...HELP????
gpracer1
Phoenix
That's what im saying if the abs box has air trapped in the system it will leave no pedal height. I had to bypass mine in order to firm up my pedal because I couldn't get the air out of it. It was more of a question, how do you bleed it? Can you actuate it while not moving?
If the abs unit is actually working ok, you could pound the brakes a few times on a dirt road to get the abs to cycle, then bleed the brakes like normal.
Or drive over 3mph to let abs initialize then jack up all 4 (without turning engine off) and spin one or two tires and hit brakes to cycle each....then bleed.
Donnie Yukonie
Yates Caretaker
upgrade to Stainless steel lines rubber lines flex and expand too much even when new steel braided does not
Archie_III
