electro
Slow speed false abs modulation occurring.
Cleaned sensors once before and stopped false modulation meow its back.
Cleaned sensor mounting surface. Cleaned sensor. Inspected sensor connector. Resistance test shows 900ohms roughly on the three sensors I have. In range according to Haynes manual.
^^^what are the ways to test a sensor anyways? Hall effect sensors?
Swapped in an older "probably fine hub" timken. Did so on both left and right side. Possibly proving good hub bearings. Inspected teeth on reluctor ring. Bearings tight. Newer rotors.
Codes in history I just cleared today.
History Codes
CO226. Left Front Wheel Speed Signal Missing
CO265 Electronic Brake Control Module Motor Relay Circuit
CO269 Excessive Dump Time
CO281 Stop Light Switch Circuit
Probably going over as much wiring as I can as soon as I can next.
What do you peeps think!? Know any good tests I can perform with basic tools?
Also does anyone know of a decent scanner for abs with the scanner and the Device for the sensor/circuit testing?
Thanks!
History Codes
Thanks!
