AFM Disable Options
j91z28d1
huh, all mine except that evap clear in a day or so.
i think I remember the o2 sensor heater recal either with a tech 2 or when you clear codes.
St. Louis
Well I haven't driven far since it's been reset. Yesterday 1.5 miles to work, then ran by Costco on way home from work, which is maybe 2 miles away, then back up to work to pick up my daughter who stayed after till 5:15. Then to/from work today. So maybe 10 miles and no highway cruising in the last 2 days
opfor2
Riverside County, CA
So, I just installed my DiabloSport Intune I3 this weekend and utilized the MPH Booster tune with AMF/DOD delete. My question is I live in the people's republic of California and I will need to have the Tahoe smoged Bi-annually. Will I need to return the tune back to OEM before I take it in, or can I leave it in?
blackelky
I would just to be safe
St. Louis
Yeah, MO needs the readiness monitors completed before passing inspection. I've had the AFM disabled with the Diablo for like 5-6 years and it passes as long as I haven't cleared any codes recently. It takes a couple days of driving to complete the readiness monitors
Marky Dissod
Does Cali fail you if it detects a non OE tune?
If the OBDII is in a non-ready state, then yes.
That's my question dies the diablo actually turn it off in the ECM unlike the plug in types of DoD bypass?
It takes a couple days of driving to complete the readiness monitors.
So, is California failing for detecting an aftermarket tune, or for detecting Not-Ready Monitors?
'cause it sounds like they're detecting Not-Ready Monitors, which the 'tune' is not properly handling.
That's NOT the same thing as detecting a 'tune'.
nashon79
