Airaid Jr and Dry Filter Installed
rbnzrcn
I didn't really notice any sound differences under normal conditions. I haven't really exercised WOT. Make sure you tight the clamps on air filter and intake side. Mine has popped off a couple times since install.
L's Truck
DC Metro
Mine has popped off a couple times too but at the throttle body. Definitely have been tightening it properly, not sure why it kept happening.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
If it's popping off, also check to see if your motor mounts are still good. My intake popped off under WOT twice in 1 week. After looking at it more, my drivers side motor mount was bad, and when I'd go WOT, the motor would move (torque) and the intake would pop off. It didn't matter how good and tight the intake was on.
PlatinumYukon
Naperville, IL
Hey guys here is a tip for you. If your intake is popping off after retightening, try washing the sleeve with warm water and soap to get all the factory oil off. If this doesnt help then email Airaid like I did and they will send you an updated SILICON sleeve! Hope this helps!
cheers
MudnRox
Rebel without a clue
Olathe, Ks
A can of Aqua-Net hair spray works very well too. I used to use it on my Dodge diesel on the silicon boots because some of them wouldn't hold under high boost.
When I installed my Air-aid Jr that's what I used and haven't had any issues.
cjweb11
Houston TX
After having it a couple weeks now I'm really starting to like the sound. I still think it sounds a little weird going from zero to WOT but once the RPMs get up just a little its great. I love the sound of moderately aggressive acceleration or WOT while the RPMs are already up a bit. I'm starting to think about not getting an exhaust, maybe just get a tip to cover the ugly factory pipe and put that 1K towards something else. We'll see, exhaust is at least moving to the back of my mod wish list for the time being.
If you want to get a little more aggressive exhaust sound without spending the money you could do the ol' resonator delete with a new tip
ADO450r
