Wake
From what I gathered when I was researching torsion key level kits…Whether you buy aftermarket reindexed keys, ford keys, or crank your stock ones...all will apply more pressure to the torsion bars thus adding the stress. The reindexed keys will only allow you to crank more than the stock keys…and this will actually allow you to apply more tension on the bars. I have a 2wd so I went with 3” lift spindles to avoid any of these problems.
From what I gathered during reading about the options it seems to me that aftermarket keys don't apply more tension on the bars to raise the truck but instead change the orientation of the bars to raise the truck. It makes sense to me as explained that it doesn't hurt the suspension feel like simply cranking the stock keys.
Am I incorrect?
