Another radaitor!!!!
purple 'hoe
Green Bay, Wisconsin
What if, the radiator is out a GMC though? Then it's not technically a "Chevy" radiator? lol
Also, between my 2 OBS trucks I've owned, I replaced a radiator once in my beater 93 ECSB 1500. Never in the Tahoe.
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
yea its 1200 for tires im going to do it myself the only thing ive never changed is a fan lutch but it doesnt look to hard like 4 bolts
bowtiefreak
No Quarter
Near Philly
Only ever put in two radiators, both on the suburban. Once because it leaked, the second time it was full of metal.....
99 2dr
The Real Nor Cal !
I would like to know how hard it would be to upgrade to the 1 ton radiator. I believe that its either a 3 or 4 pass for better cooling.
turk
Sure there no under lying cause perhaps? Maybe mixture ratio or TSB on the issue. That does seem like lot. Mine is oem Delphi and is at 243k. And a kit of others have similar time on it and are still original. I could swear that at one time I saw oil leak from the cooler section but that was months ago. Personally my oem fuel pump was acting up at 1/3 power so it got replaced today. Talk About a rocket ship. Next time you need one Nd if you are not sure you had one beforehand get a Delphi unit there are the oem supplier. And at amazon Delphi parts are 50 -60% of local store prices. Since they get them direct with out going thru distribution centers and what not.
Perhaps there is some other problem, but I'm not sure what it could be. I don't beat on my trucks, but I do use them. Especially, the 97' 3/4 ton... it is my farm truck. Maybe I've just had some bad luck when it comes to radiators... and STUPID fuel pumps. I'm on my 3rd fuel pump in my 97 chevy... and from the sounds of it my current one is soon to go out. :emotions122:
SunlitComet
OBS Jedi-Do Good
unknown at this time.
obs has square connectors on pump electrical connector which would burn out and sometimes takes the pump with it. new improved one out. 4dr that is. also clean pump ground on left frame well. as for the rad maybe being on the farm something it hitting it from below or airflow is clogged from debris in field.
Phone Man
Long Island NY
I used the aluminum one off of ebay and I love it. It's big and all metal. IMO all radiatiors with plastic tanks suck. Don't forget to convert to EL fans! The 40" will fit 2 16" fans side by side. Also a pic of the welds on the aluminum rad
mudslinger96
Texas
You should have gone with electric fans instead of the old clutch fans changed mine about two weeks ago and love them.
Bearman
