anyone bagged one?
shundal
NorCal
Do you have the aero sport or power sport airbag for the front?
When I contacted them last year, they said they use the power sport on the GM trucks. They have a few avalanches on their website done with them.
NASTY GM
Nor Cal
Are you using stock spindles with the universal bags or is it drop spindles?
Belltech drop spindles, Belltech adjustable struts and DJM arms. I don't think any of it is needed. The DJM arms help keep the wheels from tipping in when its down.
NASTY GM
Nor Cal
I don't think so. I still have 2 rings on mine. Mine would go lower if I cut up the inside top of my fenderwell. I plan on laying mine out so I just going to wait till then,
NathanJax
Vacation Nathan
Administrator
Jax, Fl
So if I use 4 it don't matter since it won't lay anyway
The front will tuck and rest on the fender on the tire if you remove the rings. So if you use more rings, it will not go as low...
sixpack19
broken arrow, ok
That's right when I installed the drop struts I never used any rings. Ok.
Also with those sport strut bags from avs does it replace the front spring on the strut? Using everything else.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I'm pretty sure they do. That's how my kelderman's do. Just remove the spring and replace with the bag
sixpack19
broken arrow, ok
Nice thanks. Since I already have norcal drop getting all air ride is half done. Easiest air ride I can think of. No link kit for rear or trimming front frame cups just front rear bags and all air components!
Rkelly1224
