Anyone interested in modifying the seat to fully recline?
C
cam3439
more pics...
C
cam3439
Some of these pics will show the bolts on the 4 corners of the seat's bottom frame/rails. Some of these bolts will be hidden underneath removable panels. I used a 7/16 and 15mm socket to remove these. Should be easy enough. You'll need various tools and sockets (metric went up to 18mm and std. went up to 15/16). I also recommend that you test your final product before you install the seat. I did this and found out that I also had to cut some of the spring. Do a mock trial on the floor to test out the mod to make sure you cut enough off of the spring.
MDMILL1
Nice write up I am still not sure if I want to do this, but at least now we have a how to.....Thanks again
blazerjohnny94
da hill
Ok cam3439 my question for you as I am in the middle of this project is did u going down the side with the notches or the other completly round side please reply this job is a complete pita
