Arnott or factory OEM? Which better?
timmyjimmy5150
Okay.... Replacing all 4 shocks on the 07 denali AWD.
People that have done this before, what is the best option: Replace factory OEM with new OEM, or go Arnott/ blistein that keep the air leveling in rear with new passive shocks in front?
Cost aside... I know the oem are more $$$$, but are they better or are the Arnotts for a cheaper price?
Tj
Ben
PCB, FL
I swapped to the arnott and blistein and i like them. I also changed out the compressor with an arnott one.
T
timmyjimmy5150
Hey Ben.
Thanks for the reply. SO you like the Arnotts/ Bilstein setup on all 4 corners better than the stock configuration, correct?
Just wondering if you could give me a little insight as to why?
I'm leaning towards the Arnotts air shocks to replace my rears so I can keep the self-leveling and the bilsteins on the struts up front.
The rears keep the auto-dampening feature but you lose it on the front struts with the Bilsteins.... Do you even notice?
You do the work yourself?
Thanks
TJ
Ben
PCB, FL
Factory setup only has air shocks in the rear I think.
Felix is correct. I'm only running the arnotts in the rear with the new arnott compressor... Actually just installed them less than a week ago. I'm still running stock up front and the ride is nice. Blisteins have always been a good shock so you can't go wrong.
puckhead
CO
I have Arnott in the rear with new pump and the work fine. Replaced several years ago and no issues.
Manshoon
Monroe makes a shock replacement also, sold on Amazon for cheap, they sell the compressor there also for as cheap @ $220, shocks are about 230'sh.
ntaphse
I installed the Monroes purchased from Rockauto and they are terrible. I'm going to switch to Belltech Street Performer asap.
rescurat
