Audio, side view cameras, 2nd Battery, Big 3
Chrismnj
Chrismnj
NJ
Very happy with the inverter, easily pull 11a 110v tool, no problem at start, next will try the microwave that it will be the real test.8A51F64E-2B73-418D-AFC6-449A4E3B2879.jpeg97778282-D65B-4C86-A88E-38BC4F056859.jpeg
Chrismnj
Chrismnj
NJ
I count 7 different taps... what are they all for???
cameras, dash cam, bully dog, trailer brake control, extra gauges, supercharger relay, compressor, some additional lighting (engine bay and inside) some other small accessories.
Gauges required one constant on +, one after ignition+, one from headlights for dimming.
Chrismnj
Chrismnj
NJ
Probably at this point I should do a sub panel, but it's getting crowded under the hood, maybe down the road.
Chrismnj
Chrismnj
NJ
Since you getting BBP tune you will no longer need bully dog correct?
Never used as a tuner, use it to monitor trans temp, engine temp, etc. have it setup so when one of them reaches dangerous temps it will give me a feedback, also reads error codes
Doug118
I added a fuse box behind my ipad in my dash. I didn't want to add go looking all over the place for constant and switched sources. It has 6 constant and 6 switched fuses
benmarkk18
