Blue gauges and HVAC
puckhead
CO
The replacement LED bulb assemblies for the gauges, domes, etc, all have resistors built-in. I just used bare single LEDs for the hvac, so you have to add resistors to keep from burning out the diodes.
Gotcha, thanks for the info! Might have to give this a try and see if my soldering skills are still any good
PavementPounder
Cincinnati
I wish I could solder. I never have and kinda afraid to try. I did the cluster and it looks sweet. Really want all the lights blue and super whites in the domes and overheads.
JKmotorsports
JKmotorsports
Austin, TX
Thanks man. I got the domes from ledlight.com as well. I don't remember the part number, but I used the 41mm 9-led festoons, super white.
str8ballin416
Las Cruces, NM
Cool. I think I found them. Did you replace all 3 bulbs in each or just the middle one out of the 3? I have 2 swivel lights in the from of mine that have different bulbs in them. Is yours the same or do you have a stationary light there. I'm anxious to get the conversion done and I think it'll look good with my setup.
This is a pic of my screens up front that I think the LED's will compliment nicely. More pics on my profile.
JKmotorsports
JKmotorsports
Austin, TX
I replaced all three in each housing and wired them to all come on. I did the puddle lights, footwells, and all four doors. Pretty much everything except the two swivel map lights.
titanium02
w7's or bust.
Norfolk, VA / ATL
Can you heat a knife and touch a stick of butter? Soldering is not welding remember.. just using a hot ass pen to melt some nickel.. the second you take the pen away, the little pool of nickel hardens.
tybardy
everyone needs a Hoe
Gilbert Arizona
holy shit that 9LED festoon is $15 ea... $90 to swap LEDS in is a bit to high for me...
I think I might go with these instead
http://www.ledlight.com/festoon-ultra-bright-led-light-1-3-4-inches-41-mm.aspx
and these for the front two....
http://www.ledlight.com/s25-20-super-flux-led-light.aspx
still not sure how i am going to do the dash and HVAC though, as it will all need to be soldered in place... i suppose im not to scared to do the soldering myself, any recomendations on what type of solder to use though? and will the standard EBAY LEDs and resistors work... AND do i use the 500 ohm resistors for the dash as well?
