Book time for engine replacement?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Wait till the spring and have a few buddies come over and knock it out
doing my 03 tahoe 4.8 engine right now at the dealership. got the labor down to 79$ hr. engine, parts such as seals gaskets plugs wires water pump total so far is 5900$
I hope that is a new engine. :)
pnwdan
pnwdan
Cunning linguist
Arlington, WA
It's about average for a V-8 engine replacement really. I'm doing a reman swap on a 2000 Camaro 3.8L V-6 right now with the same labor time.
What is the typical procedure you use for pulling these? Out the top? Remove the front end? Etc..
Sent from my SM-N920V using Tapatalk
boomboom baker
Tennessee
It is but make sure you get one of your buddies to help cause you will need some under the truck to hide the transmission in I had my wife putting helping me she's a gearhead
SLCHOE
Midvale, Utah
Out the top if it's stock height or lowered. If lifted, remove grille, radiator/condensor etc. and out the top/front.
pnwdan
pnwdan
Cunning linguist
Arlington, WA
Well it's all done. All in all it wasn't that bad. Labor intensive. It runs good now. Thanks for all the help guys.
jough
Arkansas
Jeez. I guess that I got lucky. A local shop that specializes in LS swaps found me an engine, LQ9 ($1400), matching 4L65E ($500) and installed it all (4WD) for $700. Total was $2600 OTD, but they kept my old engine & trans. They also give a 24 mo/24K mile warranty on the engine & 6 months on trans. Before installing the used engine, they put in a new oil pump, rear main seal, intake gaskets, new serp belt, plugs & wires. They also swapped over the newer water pump and alternator from my old engine for free.
So, you might look around for a small shop that does this every day.
pnwdan
pnwdan
Cunning linguist
Arlington, WA
Sounds like a good deal. Like I said. It's done. Dropped a reman in over the weekend. Up to 60 miles on it now lol.
Zumwalt
El Paso, TX
did my reman and got it on monday. so far so good, new plugs wires water pump cats gaskets pully.. runs ok i guess.. im just picky as hell and feel the difference
Nextruss
