ivin74
05 NBS Nali
What could be causing the brake pedal to be real hard when I apply the brakes on my 05 YD
check first for a leaking hose at the booster. the vac line off the booster provides the boost assistance when you Press the brake pedal. There is a diaphragm inside of the brake booster if the diaphragm is leaking suction. You need to replace the brake booster itself. But check the lines going to the brake booster and see if it is leaking some of it suction.
You are feeling non-power assisted breaking.
did you sort it out?
VikingTrad3r, I changed the hydrobooster and didnt notice much of a difference. I also noticed the steering gear leaking from the pitman joint. I'll be changing that out this weekend hopefully that will it fix the problem and keep it from creating a suction
im confused. did u find a leak in the vacuum assist for the powerbrake booster?
yep most ive seen use the same fluid as the power steering so that leak in turn should fix the low pressure of the hydroboost.
