Brake pedal is hard when braking
ivin74
05 NBS Nali
Htown, Texas
What could be causing the brake pedal to be real hard when I apply the brakes on my 05 YD
VikingTrad3r
check first for a leaking hose at the booster. the vac line off the booster provides the boost assistance when you Press the brake pedal. There is a diaphragm inside of the brake booster if the diaphragm is leaking suction. You need to replace the brake booster itself. But check the lines going to the brake booster and see if it is leaking some of it suction.
You are feeling non-power assisted breaking.
VikingTrad3r
did you sort it out?
ivin74
ivin74
05 NBS Nali
Htown, Texas
VikingTrad3r, I changed the hydrobooster and didnt notice much of a difference. I also noticed the steering gear leaking from the pitman joint. I'll be changing that out this weekend hopefully that will it fix the problem and keep it from creating a suction
VikingTrad3r
im confused. did u find a leak in the vacuum assist for the powerbrake booster?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
He doesn't have a vacuum booster. He has hydroboost which uses hydraulic pressure to assist in braking from the power steering system.
omega123
Northwest Iowa
yep most ive seen use the same fluid as the power steering so that leak in turn should fix the low pressure of the hydroboost.
Adamd913
