Braking
guidrozb1996
What types of brakes are you guys running on 2004 tahoes looking at some drilled and slotted also how many pistons are on the rear? I got 2004 LT tahoe
Sent from my SM-G892A using Tapatalk
Alot of guys, including myself, run the complete front brake setup from the nnbs. Our generation rear brakes are bigger. You can also add hydroboost in addition to that. Imo, much cheaper, and better then alot of aftermarket setups.
G
guidrozb1996
So 07-13 model?
Good stopping power?
Yup. I also swapped out to the braided steel lines which help alot. I didn't do the hydroboost mod, but I don't feel that I need it. If you do the front swap, make sure you get the caliper mounting brackets. You need those.
G
guidrozb1996
Alright cool
Bear77
South FL
Is there a link to a write up for this or direct bolt on?
newjonwayne
