thompsoj22
- Joined
- Jul 21, 2018
- Posts
- 689
- Reaction score
- 718
I do have a DR-44, actually just replaced it.
I may get one of these as when the cooling fans come on, there's a significant momentary voltage drop until the system can catch up.
I run the DENSO 220 as an upgrade, My DR-44 sit's under the hood on the tray at the front of the drivers fender in a tool bag just in case i need it. I upgraded for the exact reason you mentioned, I upgraded the electric fan motors from 500 watt to 700 watt and when they kicked on high it blanked out the bose stereo. 700 watt motors can pull 55 starting amps each when they cycle to high. Didnt hurt the bose but two 700 watt fans was overkill so i opted for 700 watt driver side and 500 watt pasenger side and this combo works perfect. Hot engine cooant enters the radiator from top hose drivers side which is my reasoning for running the big fan motor on the driver side.
