one thing I can tell you is there is no such thing as key one and key 2. Those keys are dead/dumb $1 hardware store blanks. The only functional difference between remote 1 and remote two is which is coded to the truck first and they are distinguishable to the alarm brain (remote code or freq or both?)
That means it has to be reverting to a default setting when the key is used to trigger driver preferences (when passlock is activated/authenticated). I assume the logical choice would be Driver 1.
Didn;t you say, AK that you did NOT use the PassKey Data module? That could be the (pun intended) Key variable.
NARCO:
IF you move your chair to some other position (or use easy exit), the seat moves back to D1 position?
When does it do it, upon remote usage or when you put the key in?
IF you use d2 and different presets (or leave it on CD) does it rever to D1 and D1 presets? trying to figure out how the system works for you.
ONly D1 or does it diferentiate between one remote and another?
NARCO:
