Coolant drain hose, where to buy?
Anyone know where I can get a coolant drain hose? The hose that’s connected to the radiator Petcock? Mine is missing. I’d like to do a coolant flush, and don’t want to have a huge mess draining the radiator. I did an online search, but I’ll I’m getting are radiator and heater hoses.
thanks!
OR VietVet
Multnomah Falls
Military
Willamette Valley
Post your last 8 digits of your VIN and hopefully @915_Tahoe will see it and he will help with a part number, if it still exists.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
thanks!
I read your info so your truck is a 2005 Tahoe shows
NOT SERVICED HOSE, RAD DRN **** (PART OF RADIATOR)
For my 01 Tahoe i was serviced at one point but now discontinued.
The gm# was 52479666.
Scpori
