Marky Dissod
![www.gruvenparts.com](/proxy.php?image=https%3A%2F%2Fcdn1.bigcommerce.com%2Fn-ww20x%2Flyr7tp5r%2Fproducts%2F180%2Fimages%2F530%2FBarbed_Tee__71714.1566395618.300.513.jpg%3Fc%3D2&hash=88ac1d708c4031c86d38b5edcae2182d&return_error=1)
Billet GM Heater Core Coolant Tees
Welcome to Gruven Parts, your online home for custom auto parts.
will never break but I would use spring clampsHow do these compare to the Dorman versions?![]()
Welcome to Gruven Parts, your online home for custom auto parts.www.gruvenparts.com
So this isn't a good option? And I plan to replace the ones by firewall as wellwill never break but I would use spring clamps
should be fine with the spring clamps, except for the one plastic connector..... they fix one problem and not the other lolSo this isn't a good option? And I plan to replace the ones by firewall as well
More like, your option is merely good, whereas the Gruven metal pieces are better.So this isn't a good option? And I plan to replace the ones by firewall as well.
Yeah i don't have that amount of time to wait for it right nowMore like, your option is merely good, whereas the Gruven metal pieces are better.
So 2 of these and the dorman part?More like, your option is merely good, whereas the Gruven metal pieces are better.
Although the Gruven parts do introduce twice the amount of possible points of failure/leakage with all the extra hoses and clamps for attachment.More like, your option is merely good, whereas the Gruven metal pieces are better.
You want both black tees. They last longer!One of my tees is leaking where the rear metal line connects to it and had already broken on the front like usual so I want to replace both tees. My truck has one black tee and one white tee. Everything I am finding online up until this morning was a white tee from gm. This morning in the big thread was a part number for a black one from gm and on the amazon page it is normally bought along with the white one.
Are both tees the exact same and I can just order 2 white ones? Should I just order one of each?
