Could I get some cam help please?
rcbeau1911
Finally got the trans rebuild and put in the truck. But am lost on cam choice. Was leaning toward the tsp 228r but don't wanna loose the bottom to get the pig moving and suspect the converter is to small.
Truck Info
2006 Yukon xl 5.3
4l60e full rebuild every option front to rear
3000 rpm stall
33's on 20's
Unknown rear ratio
Mods inbound/currently in progress
Holley hi-ram intake got a great deal
PRC stage 2.5 ported factory heads
TSP long tunes
Black bear tune once cam is selected
Open to any other suggestions
BlackOh7on22s
In the Garage
That intake is gonna lose bottom end also but it does look cool. I have a mild Comp cam in my 5.3 right now, Ill have to get specs for ya but I think would work great w/ your stall. This is whats done to mine
I have a K&N cold air, American Racing headers and y pipe, Corsa Sport exhaust,Comp Cams cam which Ill have to post specs later,Comp Cams 29618 springs, rocker trunion upgrade and 7.4 hardened pushrods, GM LS7 lifters and LS2 timing set, ARP headbolts, all GM gaskets and with a tune it made 340 to the rear tires. I think stock its like 250 or something at the tires.
sunshinetou22
