Cracked Dash?
Brooklyn hoe
The part that was cracked was the part over the instrument cluster and airbag, due to the cracks i was getting a lot of rattling. The pics is of the new one that I will install this weekend if I decide not to wrap the dash in leather.
fiatdale
Houstons Best
Houston
Ive done a million of these, its not bad. Just takes some time and patience. Dealer pays I think 7.5 hours repair time on them, Ive gotten it down to about 40 minutes start - finish, but I used to do them damn near weekly.
DirtyBlackHoe
Thomasville, GA
Wow
Sent from my XT1585 using Tapatalk
950410
But what is the cost for the average Joe to come in and buy one to put in himself? $400 for a big piece of plastic that cracks apart in 1-5 years is absurd IMO
fiatdale
Houstons Best
Houston
Unfortunately it is what it is. A lot of it has to do with climates and care. The other has to do with ****** product. They did change the design slightly in 2012-2013. It has almost a texturized coating on it which is supposed to be a little more durable. It just one of those ****** situations. My 07 Tahoe I bought in 2011 was cracked. My 2010 Silverado still isn't cracked. It's almost like luck of the draw
950410
Fair enough. What's confusing is some dealerships are willing to help consumers with the cost or pay for the whole damn thing while others tell you to pound sand. I wouldn't mind doing it myself if they just supplied the part.
Brooklyn hoe
Thanks guys but I still have not got around to swapping out the dash yet, due to weather and work. I have already taken the old dash apart and sold most of the parts on eBay. I only have one question and maybe Flatdale would be able to answer this question. When removing the dash how difficult is it to remove the passenger airbag is it as simple as disconnecting the battery terminals and unscrewing the bolts that keep in place. Once I am done I will post picks of the before after and during of the dashboard rebuild.
fiatdale
Houstons Best
Houston
So easy. remove the trim piece on the right side (wood grain or brushed piece) there are two 10mm bolts thru the openings behind that trim. Take those out, and I think theres one more under the glove box. Unplug it (we never disconnect battery because airbags still hold a charge regardless), and push it up from below and out of the dash. Dont try to pry up the cover from the dash. Any other help needed just PM me.
YukonCrazy
Raleigh, NC
Sure would like to see if GM will replace my dash or give me a discount while they are replacing the front airbags as part of the recall.
Raynii054
