randeez
not entirely sure.... i think similar to a camaro zl1, which using a 9.9" ring gearYou've got the power, what rear diff is in those?
Yeah I like the change of seasons. I couldn’t live where you do, I can’t take the summer heat and especially the humidity. I visited out that way once, well Virginia actually, and I’ll never go back in the summer. Plus I like the mountains with the huge trees and clear cold rivers that I can jump in and not get bit by anything except maybe a salmon.Not sure what you mean by "winter" it's like 88* here and AC in the Tahoe is on blast! The nights are a cool 50-60 tho which is great I haven't run air or heat in the house in a month.
Painting is awful so that's a major accomplishment
I wish he would help me with my rear end.
I remember seeing some stuff in that 1 diff and it’s a beast! Knowing the caddy is heavy I’d hope they did something tough like that.not entirely sure.... i think similar to a camaro zl1, which using a 9.9" ring gear
Yeah I like the change of seasons. I couldn’t live where you do, I can’t take the summer heat and especially the humidity. I visited out that way once, well Virginia actually, and I’ll never go back in the summer. Plus I like the mountains with the huge trees and clear cold rivers that I can jump in and not get bit by anything except maybe a salmon.![]()
Ya know, it just registered with me that when you asked about the wheels, I thought this shit was for your Tahoe. I was thinking "wtf is he doing 8 lug on that?"Got the front adapters on, cut the studs by a half inch or so and, mounted the dodge wheels with Chevy center caps. I think they look sweet!
I'm a little slow at times
You guys know I like to tease a little before I whip out the whole shebangtry and keep up
(i didnt have a clue wtf he was doing either till i asked a few pages back)
Can you re-drill some 6 lug?Did a little test fitting of the 2020+ 4 piston caliper to the H2 rear and it looks like unless I can find an 8x6.5 pattern rotor that’s 13.5” diameter I won’t be able to run 4pots on all four corners.
I didn’t get to try putting it on the front to see if it will clear but I have hope.
