E-Fansetup must have! Temperature Sensor fitting!!
saif najd
saif najd
Lets hope that holds up. It look like you had a dissimilar metals issue or a poorly maintained system.
So far things kinda looks fine but when I step on it I can notice the temporary heat increase above 90C then it comes down to 87C
Sent from my GT-N7100 using Tapatalk 2
saif najd
saif najd
the thermo popping open and closing?
An update!
Today I was racing a friend more like one time drag the temp raised quickly from 72c to 95c and then when I slow down it came back to 87c!!!!
Sent from my GT-I9505 using Tapatalk 2
SunlitComet
OBS Jedi-Do Good
unknown at this time.
that sounds ok for the most part with the exception that 72°C seems a bit cold. Had your engine just been started or do you run that low temp a lot?
saif najd
saif najd
True I just started,
---------- Post added at 08:58 AM ---------- Previous post was at 08:58 AM ----------
Bad thermostat? maybe some gunk from the old fitting got hung up in the stat.
I am thinkjng the same
daddy g
