yukonese
- Joined
- Nov 5, 2011
- Posts
- 48
- Reaction score
- 2
This is the first time my lovely 01 Yukon didn't make it home, in 11 years.
This morning, it ran smoothly as normal. When it's time to pick kids up from the Sunday class, the engine started OK but dropped to 1 or 2 hundreds RPM in 2~5 seconds, and struggled to rev up for a couple times, then stopped. Tried to push the gas paddle, no help. Repeated a couple times, same symptom. There seemed some smoke out from the pipe.
The Service Engine Light did come on once, OBD code said P0420-1. Does that mean O2 sensor bad? Upstream or downstream? All 4 need to be replaced? A bad catalytic converter can make the engine stall? A catalytic converter goes bad all a sudden? Any other possibility?
I have 69K miles on this 5.3L V8. I need some opinions before I call the tow truck. Thanks for your advices in advance.
