I figured I'd start an engine swap thread for future reference and for others who want to do the swap in the future. I'm about half way thru the swap process. The old still running well 335k miles 5.3 that leaked oil prodigiously is out, and on a tire and pallet. The 6.0 is on the stand and waiting to go in while I clean up the engine bay with everything out.
The 6.0 was sourced from a Pick Your Part junkyard from an 04 Yukon Denali LQ4 with unknown miles. I ordered a complete LS "rebuild kit" from WS6 Store that came referred on LS1Tech.com. Everything looked okay internally but the unknown factor led to a full rebuild, .020" O/S flat top LQ9 pistons, full cylinder head rebuild & bowl blended ports, w/ Smith Bros trunnion upgrade. The builder surmised the CR would be 10.3:1 or thereabouts after the machine work on the heads and block, along with the head gasket used. Summit Racing truck cam 8718R1, small-ish side to keep it more sleeper, and be daily driver & tow rig friendly. LS6 valve springs. Luckily the LQ4 I started with has the later Gen 4 rods with removable piston pins w/ circlips. Had those "rebuilt" with new pin bushings and the .002? O/S bearing. Crank and block was checked, decked, and refurb'd. New oil pump, bearings, hardware, etc. I had the long block professionally assembled by a local engine builder. New GM knock sensors & harness, new GM motor mounts
I have a couple questions on subtle differences noticed between the original 5.3 flexplate and motor mounts. Picture 1 shows the 5.3 with flexplate still installed and the flexplate that was on the 6.0, that came from an 04 Yukon Denali. Does it matter which one is used with the 6.0 and the original Tahoe trans? Bolt patterns seem to be the same, but the "window" cut outs are a bit different. Is there a difference in flexplates from 5.3 to 6.0 or 4L60 to 4L65? I know from my Ford days, there are different offsets & imbalance in Ford flexplates depending on engine family and year model. Is that the same case with the 5.3, 6.0?
Is there a strong reason to not re-use either of these used flexplates? What about flexplate hardware....is it single use like TTY head bolts or is it acceptable to re-use flexplate bolts?
With the motor mounts the heat shielding is different from old to new. The new ones were bought from Ebay from a seller in Ohio for $41 each that claims these are new, un-used take off GM motor mounts. The part # on the sticker is correct. Did GM change the heat shield on later year motor mounts? My original 04 motor mounts have the straight tin, metal heat shield as opposed to the wrap metal foil heat shield seen in the picture? Any GM motor mount experts can say by looking at the pic?
