@Campbesl Start with the parking brake on and put jack stands under the frame near the front doors and get the front wheels off the ground.
I suggest doing 1 side at a time.
Remove the 2 brake caliper bolts and remove the caliper and rotor.
Start by loosening the ball joint nuts until they are almost off, jack the lower control arm up a little bit maybe until the lower control arm is at ride height. At this joint your goal is to free the upper and lower ball joints. I’ve had luck with whacking the knuckle with a hammer but if I don’t care about damaging the ball joint boots I’ll just use a pickle fork.
Loosen the outer tie rod nut and remove the outer tie rod from the knuckle.
Remove the knuckle.
Remove the CV axle if you have one
Then you can remove the strut.
Then you can mark the upper control arm cams and remove the upper control arm.
Then you can remove the lower control arms, remember the longer lower control arm bolt goes in the rear and the nuts go on the side facing the rear of the Tahoe.
Then you can separate the inner and outer tie rod keeping track of how many turns.
Remove the inner tie rod from the steering rack.
Putting it back together I would start by loosely installing the lower control arm and strut, jack the lower control arm up to ride height while you assemble the rest of the suspension. It’s important to torque everything down with weight on the suspension.
From here it’s basically reverse order.
Be careful to not let the knuckle hang to the side while connected to the new lower ball joint or you’ll pinch the boot keep it straight up and down with a bungle or ratchet strap, I’ve torn boots doing that.
You’ll need some hose clamps to reattach the inner tie rod boot to the steering rack.
Turning the wheels left and right can give you easier access to the hub and brake bolts on the back of the knuckle.
Once it’s all back together only grease the zerks a little bit, you don’t want to over inflate them with grease or your boot with fail early.
Those are just some things that come to mind I hope it’s helpful. Working on these things is really easy once you get the hang of it, I can swap a wheel bearing in like 40 minutes as of yesterday.
