Fuel rail pressure
Brandon johnson
Starting my 07 Yukon XL Denali after it sits for a while doesn't start right away. It cranks over but doesn't start. Try starting again and fires right up. No codes on the das and it idles and drives fine. What's the problem?
Might want to run some Top Tier 93 through it and drop in a couple bottles of SuperTech Fuel Injector Cleaner from Wally World. Start with the simple.
If you have access to an advanced scan tool, look at the fuel pump and injectors and such. After 11 years, the top of the tank, the fuel pump area might be rusty and rotting and leaky but don't bother with that until the easy stuff has been done first.
B
Brandon johnson
I have ran 20 gallons of treated fuel thru it and plan on doing more but if it was one of those electric valves or sensors, wouldn't it throw a code? I have no dash lights.
Thanks for a fast reply.
Yes, it should throw a code if one of them is bad or out of spec even if there's a wiring problem usually. Don't mention it, happy to oblige.
HiHoeSilver
Away!
Chicago
Do you smell gas at all? After you've driven it a little bit, shimmy under and look at the passenger side of the gas tank to see if it's wet.
B
Brandon johnson
I will check that tomorrow, it's been rainy. But what would this point to if there is gas there?
HiHoeSilver
Away!
Chicago
As @swathdiver said, the lines on the head of the pump like to rust out.
This causes loss of pressure and then some long starts.
As you can see, there's a valley on top. If it's leaking, it will find its way down the passenger side.
ADO450r
