Gear codes
masterblaster
I need help !!!!
2000 tahoe ls 2WD GT4 acording to dealer Ratio 3.73. Spider gears are distroyed. Want to buy this kit at auto zone does it fit???uploadfromtaptalk1423812968349.jpg
masterblaster
A tooth came off from one of the gears and bounsed inside and everything went to crap!
---------- Post added at 05:03 AM ---------- Previous post was at 05:01 AM ----------
Do you have knowledge of rear end gears??
If u google "auto zone part number 39028" it comes upwil it fit ???? 100%??
bowtiefreak
bowtiefreak
No Quarter
Near Philly
Is this a trick question? It says on the site it fits. Go to a local store and get it, if it is wrong, they can replace it with the correct parts.
Are the spider gears all that is damaged??
airforrest
I have a 96' GMC Yukon 4x4 that may need a new front Differential soon. I have the GU6 Code in my Glovebox that says I have a 3.42 Ratio rear Axle. But it doesnt give a Code for the Front Axle, they should both be the same Ratio .........correct??
faith pounds
I have a 1999 Chevy Tahoe LS. Tires are 265/70/16. The sticker says i have a gt4 with a gear ratio of 3.73 . I was told when it was given to me it had a tow package. First, how can i check to see if it does have tow package and second, if it does do i need a higher gear ratio?
faith pounds
faith pounds
Yes. I just had the same question and was told definitely. My brother didnt and it tore up his transfer case!
Tpool
