Get a catch can before any mods.
bigrhino
l.e.s manhattan,nyc
What kind of can? Some have NPT fittings for the hoses you could retape and reinstall. Some have tops/bottoms with o-rings that could not be seated or split.
I purchased from Catchcan.com around 5 years ago. It's the 2" pcv model with the drain plug at the bottom.
kbuskill
NE. FL.
It's reverse thread more than likely. My drain plug is lefty tight, righty hissy lol..
Sent from my SAMSUNG-SM-T377A using Tapatalk
Remove the petcock/drain valve and carry it into any auto parts store. It should be a pretty standard size.
Probably 1/4" NPT.
Sam Harris
Texas
I just installed my 2” pcv model from catchcans.com. That’s a 1/4” npt fitting. I actually swapped the petcock fitting, for a ball valve.
HiHoeSilver
Away!
Chicago
Well heck, now I gotta change my oil so I can look at the bottom of mine.
Hi-psi
Atlanta, GA
Got around to installing my catch can this past weekend. Overlook the dirty engine at the moment.
20190209_162252-jpg.216042
XL04
Does anyone know if the catchcans.com is baffled and filtered?
mcguire7
