Gruven heater core T-connectors
kbuskill
kbuskill
NE. FL.
I don’t understand why they didn’t just make the nipples longer in order to accommodate better clamps. One is long enough, why not the other 2?
This was discussed and Paul asked me if there was room... I told him that the two larger ones could probably be extended but the smaller one that feeds the rear heater core might pose a problem.
As it is right now, it already pushes the rear metal lines back toward the A/C accumulator so not a ton of room without possibly bending/massaging the lines.
All of this talk about clamps and what not.... in all truth the coolant system runs less than 20psi, more like 15psi, so it's not like you have to over tighten the clamps for fear of it blowing a line off.
Worm clamps are not my favorite but I will take them all day long in this application VS the plastic T-connectors. My 2 bits.
Sam Harris
Texas
Way off topic, but I’m not talking about clamps.. so.. do the Gruven mirror gears work on the gmt800 or only the gmt900? Looks from their site, like they’re specific to the gmt900 platform.
kbuskill
kbuskill
NE. FL.
My guess is they are GMT900 specific or else Gruven would market them for both. Give Paul at Gruven a call or send him an email and I'm sure he can give an answer with certainty.
ivin74
05 NBS Nali
Htown, Texas
I think they work on the gmt800, @Rocketman did you install the Gruven heater core T-connectors on your SUV?
Geotrash
Dave
Richmond, VA
Question for those who have used these Gruven tees. I see that they also now sell billet heater core couplers for these trucks. Should I buy them in addition to the tees? And what about the tee down near the water pump? Can the Gruven tee be used to replace that one too? 2012 Denali with rear aux heat.
19724A18-DAE5-41E2-89EB-40855E13E8B0.png C257A999-ED16-4EE3-A46B-1169869DA636.png
kbuskill
kbuskill
NE. FL.
View attachment 237890 View attachment 237891
The straight connector is not needed for trucks with rear heat.
You CANNOT use a Gruven T-connector to replace the Y-connector down by the water pump BUT you can buy the Dorman 626-553 which is a direct replacement made from aluminum. That is what I used.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/113134563530
The only way you can buy it is with hoses. They don't sell it separately, I called Dorman and asked.
Madisonls98
