Headliner hole from equipment...what to do?
Derick
Indy Suburbs
Hey all, in my other intro thread I mentioned that my 2500 burb was a fire chief's vehicle. In the headliner, I have a giant hole that was used for equipment at one point in its life. Now, its just a gaping hole where I can touch the roof...and in the summer it gets hot! I thought about putting my CB up there, but it just doesnt work. The Uniden I bought was too big, and the midland unit I already have is too small. I'd like to just put a cubby of some sort up there....or I am not opposed to any sort of tech like a raspberry pi w/ a display. Maybe use it in conjunction with a backup camera. Any thoughts or previous experience?
Keanen55
HOUSTON, TX
I'd go to a local junk yard and see if they have a burban with the headliner. It should be pretty cheap.
Derick
Derick
Indy Suburbs
I've been watching junkyards like a hawk for various bits and pieces..nothing newer than like a 2001
You could always cut out a piece of cardboard, or something similar, to fit the hole, buy headliner material from the auto parts store, cover that piece with the material, then glue it in place. Simple and effective.
some shops re do headliners, that might be your best option, I've had a couple done on older vehicles before it was like $100 if I remember correctly. looked pretty dam good too
fiatdale
Houstons Best
Houston
^ Definitely find a headliner / upholstery shop. They can fix it and make it look pretty good, for not a whole lot of money. Save them time and you money by taking out most of the trim first so they can just remove it & get to work.
sanco
Chicago
There area also universal overhead consoles you can look into, either that or look for a long overhead console from a different vehicle and retrofit it for the hoe. When I had a crown vic, I put in an overhead console from an explorer, wired it up and all. not saying to use the same one but it could be your chance to add something with a bit more storage up there
schimme
