Help me figure out what I need to make my hids work on my denali?
BEEMDUB
PIMP DADDY FLEX
Michigan
So I have a kit that I bought for my 07 tahoe (55w DDM kit with 9006 bulbs for the lows) Not thinking halfway through with this I thought id use this unused kit for my yukon...Totally forgot about the HI/LO all in one bulbs and also noticed that the connector from the car is different from the ballast connector..I also forgot that I had sold my relay :emotions122: ...Anyways...What do I need to do to get this working? Buy another relay? Buy different bulbs? basically what can I salvage from the kit I already have can i at least use my ballasts?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
you can use the ballast. When you order a set of retro headlights, let them know you don't need ballast and that'll save a little bit of money.
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Not that expensive, plus he already has ballast
lol was counting down the minutes until I knew you would comment :jester: Retros will come eventually right now I have a few priority mods that need to go into the car before spending 850 on headlights haha
H13 bulbs. 07-14 No relay needed.
okay great..What about the different plugs on the headlights coming from the car? They don't even look like they match up right with my ballast connector
08grey
If you get some plug and play bulbs they will have the plug if not you can tap the wires to the headlight.
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
My problem isn't the bulb connections...it's the car harness to ballast connection it's not the same..
08grey
Yes sir the bulbs come with the wire to adapt the factory plug to the ballast plug. I sell 35w and the bulbs come with everything you need to plug into the factory harness.
---------- Post added at 01:45 PM ---------- Previous post was at 01:45 PM ----------
You need h13.
Dafrog
