Help me figure out what I need to make my hids work on my denali?
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
08grey
Are those 55w? If they are what they are in the picture those are the cheaper type with silicone holding the bulb. I'll take some pics of what to look for in a bit.
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Damnit man I totally forgot to make sure they're 55w I bet they aren't ..I'm a dumbass I'll probably have to return em and get different ones now
08grey
Look for a bulb where the bulbs itself are set in ceramic.
This is the plug that will match up with your factory plug. All you do is install the pins in the proper slot.
The better bulbs come from a factory in china GCP. These are the bulbs morrotto Ect use. They have blue and red wires from the bulb and are all built well with ceramic Ect.
---------- Post added at 09:48 PM ---------- Previous post was at 08:51 PM ----------
If you can. Stick with 35 hid. The yukon has a huge headlight bowl. The 55 watt will only have increased glare not output. You can get a much better quality set in 35w. There is allot of crap out there in 55w. My distributor only carries them because people get the fever that they are better
BEEMDUB
BEEMDUB
PIMP DADDY FLEX
Michigan
Yeah I only have 55w because I just so happened to have this unused kit here ...can I just run some 35w bulbs with the 55w ballast?
Elcaminoguy
