In need of solid H.I.D.S....
DenaliAK
Colder than you
Alaska
What happened?
I'm going out on a limb...DDM is known for this. They reverse polarity on connections. You could carefully try to find out if that's the prob. Unfortunately, I don't recall which connection is usually the culprit.
Fiddle with one and see if you can get it to fire. If so, problem solved, just repeat it on the others.
ImPrettySnazzy
from what i understand you need a relay harness to get power to the ballasts straight form the battery. my friend has the same problem in his scion tc. they sell the harnesses on ddm.
01HDtahoeNJN
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
I have some sort of harness but i received no directions and looked up directions on their site and it said nothing about that this really sucks lol
DenaliAK
Colder than you
Alaska
WTF?
Ok, that's a totally new one on me.
Do you have them hooked up with a harness to the battery or just to the headlight wiring?
Whatever the case, I'd try hooking one up whichever way they aren't to try to eliminate things. If it's a harness, it could be a short in the harness itself, etc.
---------- Post added at 04:51 PM ---------- Previous post was at 04:50 PM ----------
Nevermind, while I was typing that the question was answered.
Let me see if I can come up with a good how-to for wiring the harness. It's not hard.
---------- Post added at 04:58 PM ---------- Previous post was at 04:51 PM ----------
Here's a pretty simple but correct how-to:
http://www.ramforum.com/f75/how-wire-up-your-hid-harness-5424/
WHITEOUT
Dont Hate-Appreciate
Phoenix
my .02¢, is I would use a wire harness with fuses. Sounds like it came with a set. But seems like its over powering your electrical system. HID systems produce tons of voltage on start up!!! and may be too much for system, or not enough causing the ballasts to powemy .02¢, is I would use a wire harness with fuses. Sounds like it came with a set. But seems like its over powering your electrical system. HID systems produce tons of voltage on start up!!! and may be too much for system, or not enough causing the ballasts to powerNice to have the harness with fuses, personally, for protection of entire electric system causing the ballasts to power down. Nice to have the harness with fuses, personally, for protection of entire electric system.
Mrsharza
