Is there such thing as out of balance (engine, AC fan, etc.) that cause rough idle?
Bob2C
Northern VA
did you open with your fingers or turned ignition on and pressed the pedal to open it?
I just opened it by pushing on it so it opens. Then I held it open while I cleaned. I used a damp rag. Carbon wipes right off.
S
smokey_mountain
Did you see molybdenum coating of any kind on the butterfly? Was it damp with water or damp with TB cleaner?
Bob2C
Northern VA
I didn’t see any coating. I used a water damp cloth. And then dried it with another cloth. Simple.
BG1988
Blackbear guys were very helpful in analyzing the logs with me for the rough idle. They are A-class experts on GM motors and all analytics points that my ever persisting rough idle condition on 2018 Yukon is likely not ignition or fuel related thus no codes and very good reading in the logs.
Does anyone know if out of balance engine or out of balance AC fans condition is possible on 2018 engines?
Is there a fix for out of balance engine or AC fans? or any other engine fans?
MAF/MAP/IAT/IAC/EGR throttle control
poor spark
intermittent bad ignition coil
Torque converter
bad Bering on the accessory
vacuum leaks
issue with the transmission
other misc issues with the drive shaft stuff
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
poor spark
Torque converter
vacuum leaks
This makes me wonder about a flaky coil..... Had a neat tool I borrowed that for lack of a better name I called it a coil "sniffer". It displayed some sort of impedance value for a coil when you held the probe close to one. I used to use it to find the flaky coil on our 4.2L6 in our Envoy.
Maybe when a coil gets hot it gets goofy???
This is one like it....
https://www.jbtools.com/sheffield-t...yFOMEIWBWx282oz8lVyRZzVOL9U3hvkxoCcogQAvD_BwE
Multnomah Falls
$236 sniffer. Everyone needs one of those. I was expecting maybe $60 when I opened the link and then saw this. Can a Tech 2 do the same thing?
I have idle raised all the way to 650 now but skipping/miss is still there when engine is fully hot. It is a bit worse on Exxon 89 but my truck seems to like BP 89 or BJ's 93 best. This is not scientific at all, just what I feel. Throttle body clean seems to be the natural exploration but dealer would not do it under warranty of course and want $400 for the job...
$400 to clean the throttle body? lol wow, I clean mine all the time I must be saving a shit ton of money
all you need is a spray can of throttle body cleaner ($5 or less at auto parts store) a 8mm socket and rag
been cleaning mine regularly on all of my vehicles for the last 20+ years never had to do a relearn
Multnomah Falls
$400 is robbery. I know they say they do much more and would be interested in the list that they go thru when they do that for $400 freakin' dollars. :biggun:
PG01
Up here to the right
15k miles thats ********...
Tell you what yank the throttle plate open clean the **** out of it, even unplug it while keof let the ******* thing throw a cel remove all evidence of you being under hood then take it to the dealer play stupid and tell them to fix it under warranty
tdmcpa
