Knew my engine was not going to last long
Rosson03
Kentucky
A while back probably saw me talk about I knew my engine was not going to last long will today at pop some codes up
Looks like replacing the lifters is one of the cheaper things I will probably do what am I looking at to replace the lifters price work how to make sure it don't happen again thanks in advance
Rossen, what codes did you get? The best way to make sure this never happens again is to remove the AFM hardware completely and turn it off in the tune. You could also replace all the AFM parts with the latest designs which are far more reliable and keep using it or turn it off in the tune.
Wait a second, this happen to the 2007 Denali?
Rosson03
Rosson03
Kentucky
Yes 07 denali, the code p0300
I knew transmission goin too, I think my torque converter is shot too. Hitting gas wants to not get faster and between 40 an now 60 mph was 50,shakes pretty bad
Kraig
Random cylinder misfire could be lots of things, to include AFM lifters, but usually they don’t go all at once and you’ll have a very clear and definite miss in the affected cylinder.
Time for some troubleshooting!
Kraig
Money-wise, lifters are around $70 each at your local Chevy dealer. Lifter buckets are $20-ish each Head gaskets, head bolts, intake manifold gasket.
Or as swathdiver suggested, you can get the AFM delete kit with new cam, non-AFM lifters, lifter buckets, etc
12Yukon
I know GM fuel pumps usually go to the point it won't start, or idle for a few seconds. But, I have had a few where it gives those exact symptoms. It's always worth putting a pressure gauge on it to make sure.
Indeed. But his truck should not have AFM parts unless it was built before April of 2006. If the valley cover under the intake is flat, he doesn't have it.
Rossen, what are you using to pull codes? Do you have a bi-directional scan tool? Can the scan tool pull up the snapshot showing why P0300 set? Live in Florida by chance?
Rosson03
Rosson03
Kentucky
Swoth diver I went to AutoZone and got them check
Thank you will be cheaper to get another engine down the long run
Could you also put me in a good post about the 6-speed vs. 8-speed transmission I saw something a while go. Wonder if it's possible
Rosson03
Rosson03
Kentucky
I've been reading on that deleting that AFM cool stuff, what were y'all recommend on cam I don't mind spending a little money on an upgrade
Jeremytahoe
