LED dash pics and specs and crap
the big blue bus
richmond, va
apon looking at it today seems im missing the drivers side courtesy light but i have the passenger. so from the thread posted a lil while back those 4 bulbs should be the same ones? and should i get the wled-x5s with 220 degree or would i be good with say the wled-x with 120 degree light or even the 90 degree ones? im not woried about hot spots there so i guess i dont need the wide angle ones and the 120 ones are cheaper by a lot. im going to order new ones of those and 4wd thing for now. will do guages when i do new radio
haks310
Got LEDs?
SoCal
It is soldered in so you can use whatever bulb fits in there.
haks310
Got LEDs?
SoCal
T1.5 or NEO wedge bulbs are smaller.
But I am sure you can just go to Radioshack and pickup a couple of LEDs from there and they would work.
Devious_Tahoe96
Mr. Budwieser
West Texas
How do you replace the license plate bulbs?? do you have to remove the bumper??? Thinking of putting WLED-x-x LED bulb UV Blacklight bulb since my license plates are white im thinking it'll stand out. Any opinions on that or should i just use a white led instead??
haks310
Got LEDs?
SoCal
White.
Crawl your ass under there and check it out. Getting dirty is not a bad thing.
LoL and GM isn't dumb enough to make you remove the whole bumper to replace two light bulbs. Get under there behind the plate..you'll see the two sockets on each side...twist those out and you'll be able to get at the bulbs, simple plug and play.
Stevemo70
