low coolant light
bkboatnsleds
McHenry, IL
man I like the thought of converting to 6.0 but don't like the thought of spending cash right now.
And your situation is so similar to mine it uncanny....so I'm fearing that it is indeed the same issue....especially since my yukon is such an early model.
Is your yukon a 4x4? Im wondering if the 4l65e tranny will bolt up without a ton of mods.
Yep 4x4 , sounds like you might luck out - I didn't ever have any signs of coolant anywhere, no smoke no nothing.. Just took it in about 1/2 gallon a month.
TWITCH101
TWITCH101
well I'll pull the heads this weekend and we will know for sure if that is the problem. If so, I'll be investigating an LQ4 Motor that is within driving distance.
ATL
the 4l65e will bolt right up as thats what came with the 6.0s
TWITCH101
TWITCH101
I meant bolt up to my crossmember in my yukon...
ATL
agh, im not sure of that but i dont see why it wouldnt. as far as i know the 60e and 65e have the same housings
TWITCH101
TWITCH101
Yea..I would think they would be the same but I can't bank on it.
---------- Post added at 11:04 AM ---------- Previous post was at 11:01 AM ----------
Can I pull my valve covers off without removing my intake? I wanna check for sludge and fluids....I would think by now with 160k miles I would have plentiful sludge if my heads were cracked.
bkboatnsleds
McHenry, IL
I'd agree - its the internals that are different - the 80s wont be a direct bolt up
---------- Post added at 09:38 PM ---------- Previous post was at 09:37 PM ----------
Yeah you should be able to - just pull coil packs off
TWITCH101
TWITCH101
For anyone who is changing their water pump....go ahead and buy an Ac compressor belt and replace it while your in there. Mine was shot and with summer coming up fast it was a no brainer. As for the heads issue, I'm just going to let it go and buy a 6.0 and wait on the 5.3 to either crap out or burn enough fluid to make it a priority to swap
Kman
Southern California
Might as well change the tensioner while you're in there also.
gatorboi
