Mild 6.0L Build Suggestions?
So does the adjustable pushrod have a spring in it? Like for some kind of VVT simulation?
Or is it just set once to length?
You're like an LS mad scientist.
You should invite chris and jeremy over for dinner and beer and do a QA walkthrough.
Precision in a factory design is what I like about the LS platform! I'd rather spend hours on one step to nail a tight tolerance than get a dozen items done "close enough".
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
My latest news, Roger doesnt sell pushrods longer than 7.450 inches. I am bot sure where else to get custom length pushrods?
Sent from my SM-A505U using Tapatalk
fasteddy
Dude,
I saw your weiner post over on LS1tech.
You are so spoiled!
You have Tony Mamo advising you on your solid roller build.
He's like the world's leading expert on heads and valvetrains.
You'll be Mamo-ized.
Your in good hands now.....sheesh.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Dude,
You are so spoiled!
He really REALLY seems to know his stuff! Is he Darth_V8r? The Tony Mamo from AFR?
fasteddy
Yes......The Tony Mamo. You have the only Mamo Tahoe!
Now you need a bigger cam, yella terra rockers and a ported manifold....LOL
More fuel, bigger injectors and an 8K tachometer.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Sweet! He has been answering a lot of my posts on there. Reading his guide he wrote on valve setup :) Very helpful guy.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Ordered custom pushrods from Manton pushrods. Super helpful, bit more than ordering off the shelf... but when figure in the rods build pretty cheap. Getting much thicker rods for $240 in 3 different lengths... and they will are building so same volume of oil will get to rockers as with stock lifters :) I asked they use a smaller oil hole for that reason and they said that is what they recommend for my build for that very reason.
Question, where can I get a differend oil spout on valve cover? And how does old one unscrew from valve cover?f343324a03ba0ddb005c5bd5a5b7eb3f.jpg5036514d052902c86da0c6d628be7a4a.jpg
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
FML do you guys think this weld will seal up?
I have no truck to get exhaust to shop. I suck at welding. I loaned my angle grinfer and cutoff wheel out and didnt get it back.
I cannot get welder to weld wo splattering everywhere.
This is for my wideband o2762e8a761661faef92b7d10c509d4c01.jpg10b06de8d0a1268332f1fb869530fe06.jpga8032c3c0761e835c73990b06738824c.jpg
Go get your angle grinder and cutoff wheel back from the ungrateful sob who "borrowed" it.
Obstahoe
