Ordered custom pushrods from Manton pushrods. Super helpful, bit more than ordering off the shelf... but when figure in the rods build pretty cheap. Getting much thicker rods for $240 in 3 different lengths... and they will are building so same volume of oil will get to rockers as with stock liftersI asked they use a smaller oil hole for that reason and they said that is what they recommend for my build for that very reason.
Question, where can I get a differend oil spout on valve cover? And how does old one unscrew from valve cover?
Sent from my SM-A505U using Tapatalk
hahaha, I am second guessing having bought that welder. @Jimmyy interestingly no need to tap it. It's the same threads as the Bosch wideband O2 sensor I bought. I wanted to make a perinate hole though so I could run everything at once.I don’t weld but if I did it would look like that. Can you tap the old one?
