monster in a box question
jjh
OK so I think I have decided on buying a monster in a box rebuild kit. Was wondering if there was anything else I should get? Any more input would be great. If your not familiar with this kit here is what comes with it. Also thinking of getting a new torque converter maybe 1650 stall. I don't plan on adding any power to the motor and just plan on towing. Do I need a shift kit?
Mega Monster Rebuild Kit Includes:
▪ Paper Gaskets
▪ O-Rings
▪ Lip Seals
▪ (3) Molded Pistons
▪ Sealing Rings
▪ 4L60E Corvette 2nd Gear Servo
▪ Friction Clutch Plates
▪ Steel Plates
▪ 3-4 Kolene Steel Kit
▪ 3-4 Performance Clutch Kit
▪ 4L60E Filter
▪ 4L60E Heavy Duty Kevlar Band
▪ Teflon Pump Bushing
▪ Delco Front Seal Retainer Clip
▪ 4L60E Superior Shift Reprogramming Kit
▪ Hardened Pump Rings
▪ 4L60E 13 Vane Rotor Gear
▪ 4L60E 13 Vane Rotor Guide
▪ 4L60E 13 Vane High Rev Kit
▪ Heavy Duty "Beast" Sun Shell
▪ Heavy Duty 29 Element Sprag
▪ Heavy Duty Wide Rear Sprag
▪ New Electronics Included
▪ 1-2 Shift Solenoid
▪ 2-3 Shift Solenoid
▪ Manifold Switch
▪ EPC Motor
▪ 3-2 Solenoid
▪ PWM Solenoid
▪ TCC Solenoid with Harness
livingez_123
Sandy, OR
That's what I put in mine. Take your time and get your clearances right. try to get them towards the low side of spec. Yes you need the shift kit. It helps with line pressure and coolant flow to the cooler.
J
jjh
So I don't need anything else than whats in this package? Sorry to sound like I'm new to this, problem is this is my first automatic I've messed with. Use to standard trannys.
livingez_123
Sandy, OR
I would recommend getting the shop manual to help you with the rebuild. There not a difficult trans to do but there are a few tools that will make life a bit easier for you.
xanatost
Lafayette, La.
Get the upgraded sun shell "The Beast".
Never mind I just saw it on your list. I rebuilt mine so have fun :)
retorq
Kingman AZ
There are better shells then the beast now a days, go with the Sonnax SmartShell, much better piece and it actually addresses the REAL issue.
J
jjh
I can't seem to find the sonex anywhere maybe I'm missing it
pugnaxx
