Thank you Mark.Coming together nicely.![]()
Mark, I can tell by your build thread that you are a detailed sort of guy and do your research and study. So I don't expect you will have any real issues if and when you do something like this build. I really haven't run into any real issues. I've only ran into two challenges:At this point, have you run into any challenges or issues a guy should know about or has it been pretty straightforward?
Pulled alignment tool and installed seal.
Both timing cover and rear cover completely flush with block.
@iamdub I've watched so many videos and it was split almost 50/50 on install. Most people don't want to spend the money on the alignment tools so they proceed the way you mentioned - which is perfectly ok and was the way I was going to go. I reached out to Texas Speed and they stated they use the tool method but they build lots and lots of engines. I decided to go the tool route - so simple and the tool set comes with a u-shaped plate to ensure the cover and oil pan alignment is essentially perfect. As for your question about keeping the lips aimed perfectly - not an issue. By the way, I used your suggestion about the RTV.I've never installed a RMS after the cover was on. I've always had the seal in the cover with the donut that guides it and pops out to keep the lips on the seal leaning forward. Did you have any problems keeping the lips aimed properly with this method?
