Mystery noise from the rear
blackcoffee
O.G. Black.
What Bass1775 said.
---------- Post added at 06:29 PM ---------- Previous post was at 06:29 PM ----------
To add to it I guess my front left axle is going out when I do u-turns or tight turns that thing starts clankin and knockin DRIVES ME NUTS!
bowtiefreak
bowtiefreak
No Quarter
Near Philly
It onlt does it on a stop. Just put new U bolts in and I will drive it later to test it out.
Mad man, I will check the bushings, thanks!
FootinSD
South Dakota/Utah
Most of these trucks do this. I've been told that is the slipyoke in the trans. The remedy they say is to remove the driveshaft and grease the yoke that slips in the transmission. The trans fluid is supposed to lubricate this but . . . . I' personally have not tried this remedy but, my truck does make that noise when I come to a complete stop.
I had my rear driveshaft yoke greased up with a good synthetic grease and the noise you guys are describing went away for me. The transmission guy said this is a common thing with tahoe's of our age, and its an extremely cheap thing to do, even if it isnt making noise. I paid $30 for him to do it.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
My slip ykoe is greased, I did it not to long ago. everything is new on the truck. Just need to go drive this thing to test it out but I bet the new bolts did it. the others where messed up and just crappy parts
bowtiefreak
bowtiefreak
No Quarter
Near Philly
Update: no noise yet. I new GM bolts seem to have solved it. The width on the factory bolts in tighter to the spring, the thread is better too, the ****** other bolts had a very fine thread and the side I questioned was stripped a little and when I went to take it off it was not really tight. Been driving all week and have not heard the noise so my conclusion so far is the rear was shifting on me. Nice huh? Thanks for all the advice as always.
jdawg901
memphis tn.
what type of lube did u use on your yoke ots been rainin alot here so sat. will be the day ill replace u joints.
jdawg901
memphis tn.
fixed it it was the front u joint by the trans case back was fine but replaced any way bought some syn.grease lubed yokes and joinnts real good all good now ,now on to the next
